PLEASE HELP
After looking online at shcematics of this tactile switch, I thought i could bypass it with a simple short wire solder job.
This of course didnt work :/
I have some knowledge of electronics but clearly not enough :/
My goal is to bypass this tactile power switch and have the de-humidifier turn on as soon as its plugged in and switched on from the wall socket.
The settings seem to always be in memory regardless, e.g humidity level and fan speed etc.
After seeing the schematic of the tactile switch which seemed simple, I proceeded to solder a short wire from one side of the switch to the other, that being said, before doing this i checked continuity first of all 4 prongs in which 2 already showed continuity and also the opposite 2 also had continuity.
So i Joined these together.
Upon doing this the de-humdifier turned on and off and on and off intermitently..........so then something clicked in my novice brain, It's a TACTILE button.
So my question is, which i guess you've already gathered. I'd like to bypass the tactile switch and power on from wall plug only if possible.
If you would like to know why...........I have a humidifier and de-humidifier and a controller with a 2 plug relay, and while the humidfier turns on from the controller the de-humidfier only gets supplied power to the be turned on manually with that Damn tactile switch
It's an old unit btw but any help would be much appreciated.
Thank You
I will be also happy to upload pictures of the pcb if no ifo can be found readily online.
B&Q.........DE-HUMIDFIER
MODEL.........WDH-716DF-16R
Thank You
