DC to AC variable frequency sine wave generator
Giacomo Mazza
Joined Jun 1, 2016
8
Hi everyone,
I'm designign a robot lawn mower. The problem is to make it understand where the boundary is. Doing some research i understand that the best method is to bury a wire in the ground in which pass an AC current and measure the variable magnetic field generated by the wire with a coil mounted in the robot. I tried with the 230V @ 50Hz of m home grid but the magnetic field was to low to be measured at the distance i need. so i understand that i need more current and a higher frequency than the 50Hz and 1mA i tried before. I'm looking for a circuit capable of generating a sine wave at max 50kHz and at 5-10 V and 1-2 amps.
thanks in advance
ian field
Joined Oct 27, 2012
6,536
since this is not an insurance policy forum but an electronic one i would find suggestion about the circuit more useful
The big problem is frequencies already in the environment that might confuse your robot. The local mains frequency being the most obvious, probably there's still enough old CRT TVs around for horizontal scan frequency can't be ruled out.
Maybe somewhere in the range; 25 - 40kHz is best - you should certainly avoid the RF spectrum.
30,834
You are better off, and safer to go with low voltage-higher current, it should be fairly trivial to make a 50hz detector by inductive pickup.
Giacomo Mazza
Joined Jun 1, 2016
8
In fact, I saw another similar project that used a 555 oscillator at 34kHz and to measure used a coil in parallel with a capacitor to make a resonant circuit at that particular frequency. About the power involved i think i may start with a single 555 that is capable of sink/sourcing 200mA and if needed add some in parallel to achieve the desired power
Giacomo Mazza
Joined Jun 1, 2016
8
i said before that i need a low voltage high power. the one with 230V 50Hz was just a try to prove that the principle could work
dl324
Joined Mar 30, 2015
18,476
abot the dogfence i think it would be more expensive since i need 4 sensor, one in each corner of the robot
Why? The response to the fence isn't a step function. My neighbors dog would get a running start when he approached the fence so he'd be past it before it bothered him. If the range was so short, it wouldn't be effective.
Giacomo Mazza
Joined Jun 1, 2016
8
i need 4 because the robot must be able to follow the boundary wire to the charging station s othere must be 2 sensor on each border to follow the wire
dl324
Joined Mar 30, 2015
18,476
Giacomo Mazza
Joined Jun 1, 2016
8
When its following the cable it actually needs only One coil but consider this scenario: it's arriving at 45 degrees at the boundary, you only sense the magnetic field with the coil close to the wire then how do you know how many degrees you have to turn to be parallel to the cable?
ian field
Joined Oct 27, 2012
6,536
You could try searching electronic pipe de scaler schematics.
Most have a few turns of thick wire around the pipe and pass a current through it at a few tens of kHz.
Typical circuits use a frequency that would be easy to tune a receptor in the robot to. The voltage involved is certainly safe, and the current isn't all that much either.
Giacomo Mazza
Joined Jun 1, 2016
8
I already tried with a magnetoresistive sensor but it's pointless. I find the induction method the best. I only need a circuit capable of generating a sine wave with an amplitude of few volts in the order of 10 and a current of max 2 amps.
DickCappels
Joined Aug 21, 2008
10,661
10V @ 2A into a loop antenna -you probably don't really need that much power and if you did use that much power you might run up against legal problems.
The circuit below transmits at 187.4 kHz, a frequency that is permitted up to 1 watt input to the output amplifier "the final stage" in the United States. You could scale it in power by changing that 330 ohm resistor and you can change it in frequency (probably illegal in the U.S., don't know where you are) by changing the tap on the counters in the CD4060.
Instead of the loop antenna, you can use your buried wire as a loop and resonate that with a suitable capacitor.
The AT90S2313 is a microcontroller that keys the transmitter. For your purpose you could use and NE555 to generate at square wave if you want tone modulation. If you just want the carrier, you can omit the 4.7 k resistor and the 1N4148 as well as the controller.
While we are at it, below is a 1 watt output stage. Modulate it or don't. The two capacitor impedance transformation network will depend upon the inductance of your antenna.
