DC TO AC CONVERTION USING ANALOG CIRCUIT FOR INDUCTION COIL
Pradeep.etce
Joined Jun 28, 2023
16
Hi everyone,
from last some days i am working on a circuit which converts the dc voltage into the ac. In the circuit is used astable multivibrator for generate the PWM to operate the mosfet. I used totem pole circuit drive the gate of mosfet. The problem is don't know what to do next. I know the principle of induction coil and start working to design a induction coil, i designed the switching circuit and generates the frequency but next step is to make circuit to convert dc voltage into ac which going to flow in coil for induction, i want to do this by using only two mosfets. I know a circuit which suitable for my application( In this circuit the center tapping coil is used. but I don't want to use extra inductor coil for circuit. I am looking something like H bridge circuit for change the polarity of the supply. If anyone know about that please let me know.
Here i found a circuit for same application, i tried but didn't understand the complete working of that circuit : https://1drv.ms/i/s!Ao-7jX45jaA4gaxPramT7a1BKNuIRA?e=xQxXNx
ericgibbs
Joined Jan 29, 2010
21,644
Hi
You already have a Thread on this topic which has been Closed.
Is this new Thread in any way discussing Free Energy or Over Unity Projects.?
Moderation.
Pradeep.etce
Joined Jun 28, 2023
16
Hi Pradeep,
Free Energy or Over Unity Projects are not allowed on AAC Forums.
Moderation.
I take a reference circuit of buck converter i need to change input voltage range of this circuit, can you help me in that ?
and i tried to simulate but in simulation its doesn't work. Can you know the circuit problem?EG57_ 928.png
Alec_t
Joined Sep 17, 2013
15,167
1) Please post a link to that reference circuit.
2) What is the present input voltage range and what is the range you want?
3) What is the intended output voltage?
With L1 connected to the circuit ground that's not surprising!
Ian0
Joined Aug 7, 2020
13,317
The UC3842 isn't good for Buck regulators. It would make a good boost regulator, or even a SEPIC, but not a buck.
Pradeep.etce
Joined Jun 28, 2023
16
INPUT VOLTAGE RANGE IS 36V TO 80 VOLT AND OUTPUT IS FIX 12VOLT/3A.
IT IS A BUCK CONVERTER INSTALLED IN ELECTRICK SCOOTY, ITS CHINIES PRODUCT.
"With L1 connected to the circuit ground that's not surprising!" Yes, me also, but in simulation i checked i will not work without that connection.
I design another circuit by studying the datasheet of the ic, i have a doubt, in datasheet there is mestioned input voltage range is 12v-30v. and in simulation when i check the vcc pin have 100 volt when input volt is 100v. Please have look on circuit and help to solve this issue. output will be ok. but vcc pin of ic having high voltage and in simulation it works properly. Can i move to make prototype for this circuit for test it in real life?
The circuit diagram and output is in attachment.
Alec_t
Joined Sep 17, 2013
15,167
Why are you applying 100V to the Vcc pin of the LT1241? The Absolute Maximum is specified as 25V !
In the application circuit in the datasheet the offline Vcc voltage is limited by a 15V zener.
Pradeep.etce
Joined Jun 28, 2023
16
i tried by voltage divider and 30 volt zener diode but in that case the output is not come( output will become 100-500 microvolt). please suggest a circuit for power up the LT1241 ic. input voltage range is 30v to 100v.
