I have designed a 5V ,350mA fixed power supply with a 12 Vrms step down transformer. the voltage across filtering capicitor should be almost peak value i.e 15V or 16V . but I am getting 12 volts acrossthe capacitor why is it so.
The capacitor gets charged by the peaks only so the charge current is quite high. This makes the drop across the 1 ohm and the diodes higher than you think.I have designed a 5V ,350mA fixed power supply with a 12 Vrms step down transformer. the voltage across filtering capicitor should be almost peak value i.e 15V or 16V . but I am getting 12 volts acrossthe capacitor why is it so.
Typing in all caps on a forum (or e-mail) is considered the equivalent of shouting and it is also considered quite rude. Please refrain from the practice (except, of course, when your intent is to shout and be rude).SIR THIS IS OUR LAB PROJECT USING ZENER MY QUESTION IS WHY VOLTAGE DROPS ACROSS CAPACITOR THEORY BASED ANSWER NEEDED
| C | Choosing the Right Power Supply for a Long LED Strip | General Electronics Chat | 11 | |
| C | Choosing a power supply for a long LED strip | Power Electronics | 10 | |
| K | Power Supply for Guitar pedals | Power Electronics | 17 | |
| D | DC motor controller/power supply | Power Electronics | 17 | |
Alternative power supply | Power Electronics | 2 |
