DC Power Supply
Ahmed Zafar Khan
Joined Feb 18, 2016
12
I have designed a 5V ,350mA fixed power supply with a 12 Vrms step down transformer. the voltage across filtering capicitor should be almost peak value i.e 15V or 16V . but I am getting 12 volts acrossthe capacitor why is it so.
12,262
Schematic.
Is the supply loaded at 350 mA when you are measuring the voltage?
Schematic.
What is the size of the filter capacitor?
Schematic.
Dodgydave
Joined Jun 22, 2012
11,395
NO, you have resistors in series with the output supply, and the zener is pulling too much current through the resistors, i would use a lm7805 regulator instead of the resistors and zener.
ronv
Joined Nov 12, 2008
3,770
The capacitor gets charged by the peaks only so the charge current is quite high. This makes the drop across the 1 ohm and the diodes higher than you think.
33,126
What is the average current through the 15 Ω resistor between the cap and the zener?
What fraction of the time do the diodes spend conducting?
What is the average current through the 1 Ω resistor between the bridge and the cap?
What is the average voltage drop across that 1 Ω resistor?
33,126
SIR THIS IS OUR LAB PROJECT USING ZENER MY QUESTION IS WHY VOLTAGE DROPS ACROSS CAPACITOR THEORY BASED ANSWER NEEDED
Typing in all caps on a forum (or e-mail) is considered the equivalent of shouting and it is also considered quite rude. Please refrain from the practice (except, of course, when your intent is to shout and be rude).
