Hello to all... I am a member of many different forums on the internet, but I am new to this one. And I know how frustrating it can be for these types of posts: But I am a newbie when it comes to these kinds of electronics. I am no stranger to soldering, but I dont know that much about capacitors, resistors, etc.... But, I have a pretty straight foward question to ask so hopefully, I wont be too much of a PITA
What I have done is put a computer in my car, or a Carputer if you will. For anyone interested in the hobby, you can go to www.mp3car.com to learn all about it. But, what I am trying to do is get my computer to Startup and Shutdown with my cars ignition. So it would be turn key on>start computer>drive. Then turn off ignition>remove key>shutdown.
I have built a series of relays to do this, but the problem is my particular DC-AC Power Inverter does not survive crank. So when I turn my car on, the inverter dies.
Now what I have tried to do is build a power on delay circuit that I found online at this site: http://ourworld.compuserve.com/homepages/Bill_Bowden/page2.htm#delay.gif It works just fine and I have gotten a 5 second delay out of it.
Also, I have built this circuit: http://www.mp3car.com/vbulletin/showpost.php?p=465359&postcount=29 which uses the power from the capacitors after the 12volt line is cut to keep the relay alive for around 2 minutes and 30 seconds. Which gives the PC enough time to properly shut itself down. Again, this works just fine.
HOWEVER, I cant figure out how to wire them in sequence because they both use a trigger output of negitive ground. So if I use the power on delay circuit to supply ground to the power off delay circuit, when the car is shut off everything dies with no power off delay.
So, what I am trying to ask is: Can anybody tell me how to wire those two circuits up to give me a 5 second power on delay, and a 190 second power off delay. OR, is there a better way to do what I am trying to do, and another circuit I should use....
Thank you very much in advance for any help you can give me. I apreciate all comments, and ideas. And again, I'm sorry for the lack of electronics knowledge to properly word my question
