DC Motor
AlbertHall
Joined Jun 4, 2014
12,625
If the stator is intended for the same voltage as the rotor then it will work just fine as shunt wound.
It is unlikely to work properly as a series wound motor as the stator will be designed for lower currents than the rotor.
MaxHeadRoom
Joined Jul 18, 2013
30,661
How would you intend to self excite a wound field?
If you rely on residual magnetism you can get a runaway condition, possibly to destruction.
How would you produce a self exited series motor?
Max.
