MisterBill2
- Joined Jan 23, 2018
- 28,042
When a DC motor draws excessive current it is either overloaded or stalled. So the simple ways to sense that are to monitor either voltage or current, depending on the power source internal resistance. Voltage monitoring using a comparator is easier and simpler, but depends very much on the power source properties. The alternatives are monitoring the RPM or the power noise spectrum. Overloading increases the brush (commutation) noise while stall causes it to cease. So possibly monitoring brush noise would be the best detector of actual stalling. It may possibly even be the simplest method.
