DC measuring
Paul18
Joined Aug 1, 2019
7
Need help.
Which DC current can you measure according to picture a, b, c?
ericgibbs
Joined Jan 29, 2010
21,551
hi Paul,
Welcome to AAC.
As this is an Homework assignment, post what you think the answer is to the question, we can help.
E
ericgibbs
Joined Jan 29, 2010
21,551
hi P,
Consider that the voltage may be stated in 22.5Vac as an RMS value.... what difference would that make to the rectified/ smoothed output voltage.??
E
ericgibbs
Joined Jan 29, 2010
21,551
No difference.
hi,
Usually transformer voltages are specified in RMS, so for example a transformer secondary specified as 10Vac would mean 10V rms.
As you may know the peak voltage output for that transformer would be 10V * 1.414 = 14.14V peak.
So applying the same equations for Vpeak for your 20.5Vrms, what would the peak be and what would the DC voltage output.
I suggest you confirm what the 22.5Veff represents, ask your Tutor.
E
