dc-dc step up transformer
RISHI HAZRA
Joined Jan 16, 2014
15
I need to make a transformer to step up 0.3 V to around 3 V to light LEDs . My power source is dc . This transformer has to produce a dc stepped up voltage. That is why I am using it with this circuit which I came across recently.
http://www.google.com/patents/US4734658
Can anyone please help me with the size and the frequency of the transformer. This is the rough estimate I have prepared but frequency of operation still confuses me.
frequency = 50 Hz (assumed)
N1 = 10 turns (primary)
N2 = 1000 turns (secondary)
dimensions of core = 1.5 * 1.5 sq cm
flux density for normal steel core = 1 Wb/ sq m
DickCappels
Joined Aug 21, 2008
10,661
Careful you don't destroy your FET -the ratio of 3:0.3 is 10. Your primary to secondary turns ratio is 100, which means that you are likely to exceed the allowable reverse gate voltage.
Is there any special reason to design this for 50 Hz? This sort of thing is often done at tens of KHz or higher. It could save you a lot of money on copper and ferrite.
22,083
It says right in the abstract that it is a stepped up AC voltage. See, here's the thing. Transformers don't work with DC, they only work with AC. Here's another thing. when you step up the voltage you step down the current. This happens in such a way that you always get less power out than you put in. What is the source of the 0.3VDC and how much current can it supply?
RISHI HAZRA
Joined Jan 16, 2014
15
yeah you are probably right but the patent requires me to have 1:100 turns ratio. I was thinking of making a 1:10 first. I have no idea about the frequency of operation. I guess, since its dc, the frequency will depend on the FET which is as you say thousands of Hz. I assumed 50 Hz in order to make my dimensions pragmatic
E= 4.44 B*f*N*A
Can you please help me chose a frequency and the dimensions
RISHI HAZRA
Joined Jan 16, 2014
15
Its more than 100 mW but in order to light the leds, I require about 0.5 mW. So, power's not a matter. Its the voltage that bothers me. My project restricts me form using any external source. Hence op-amps are out of question.
DickCappels
Joined Aug 21, 2008
10,661
Do you have a diagram of your circuit? For example, will you take power from the circuit while the JFET is conducting or when it is off, or both? Are you going to pass the voltage through a rectifier and filter it or just let the LED clamp the voltage?
Have you selected a JFET yet?
Do you really only 170 microamps?
And a key question: Do you already have some ferrite cores on hand?
Let me just add that in a blocking oscillator, the frequency of operation is defined by everything in the circuit, and it turns out (as far as I know) to be the best frequency for that combination of parts.
22,083
I'm not clear about your numbers.
If your input power is 0.5 mW @ 0.3 VDC that means the current you can draw from this supply is 1.667 Amperes
If the conversion process is 80 % efficient then your output power will be 0.4 mW
For an output power of 0.4 mW at 3 VDC you current will be 133 mA
Is this what you have in mind?
One other point. Just because a patent is granted does not imply that the claims are true, or that a device described within can be made operational by someone skilled in the art. It just means that the patent office was too busy to verify any of the claims. Taking their claims on faith is IMHO the road to perdition.
RISHI HAZRA
Joined Jan 16, 2014
15
The FET if J110. I do not have ferrite cores as of now. Since I haven't finalized my core dimensions yet. The circuit diagram can be found in the link posted above.
The frequency of oscillation is determined by the speed of the feedback loop. For this particular oscillator, the speed of the feedback is determined primarly by the inductance of the transformer T1 primary 15, the gate to source capacitance C3 of the field effect transistor Q1, and to a lesser extent the drain to source capacitance C2 of the field effect transistor Q1.
Yeah I am gonna pass the ouptput voltage of the secondary through a rectifier in order to light the leds
RISHI HAZRA
Joined Jan 16, 2014
15
So this is what I am trying to do.
I have a 0.3 V input which I need to step up to about 3 V. As I already mentioned, the power requirements are being met even after stepping up the input for LEDs require about 0.5mW to light up but at 3 V. I have tried using many other options before I came across this. The input is DC. Can you please help me with any other option. Kind of desperate about making this project, you know
Tesla23
Joined May 10, 2009
560
Does any of you think it is possible with a 0.3V DC input
I'd be surprised if you can get much efficiency or power, but you can probably make an oscillator. Some time ago in response to some questions here, I made a FET oscillator that operated down to 43mV, so who knows what you could do with 300mV!
(from http://forum.allaboutcircuits.com/t...tra-low-voltage-oscillator.44492/#post-288608 )
With a J310 FET and a 70turn:1turn transformer wound on an old Amidon toroid (so only 2 components), it reliably oscillated at 3.2MHz from 43mV drawing 1.6mA. It needed 43mV to start and dropped out below 41mV.
At 43mV it happily allowed a 1m 50 ohm coax connected to the drain to a 1Meg input impedance on a scope to observe a reasonable looking sinusoid of about 15mV p-p. Connecting the coax only changed the frequency about 3kHz.
Placing a 10:1 scope probe on the gate reduced the frequency to 2.4MHz and increased the supply voltage needed to 66mV, but then showed a 1.13V p-p reasonable sinusoidal waveform.
