DC-DC Buck converter with bypass mode
Suly
Joined Apr 2, 2019
I want to add to my device a DC-DC buck converter that has a wide range input from approximately 10-30VDC with an output of 12V fixed. However, because the input is a battery and the voltage might drop (as stated from 10-30), my buck converter will stop bucking. i was looking for an ic that has a bypass mode but did not find one for this input range. so i decided to look into designing one myself, can anyone help me with some ideas?
Thanks...
mvas
Joined Jun 19, 2017
539
How about a Buck-Boost Converter?
If not then ...
Will your bypass device use a MOSFET or Relay ?
Sense the Low Battery Voltage and then switch your bypass device ON.
Use hysteresis to prevent chatter
Suly
Joined Apr 2, 2019
i forgot to mention i have a target price and limited components. a buck boost converter will cost me more than 3 dollars.
Suly
Joined Apr 2, 2019
If not then ...
I just want to add a baypass circuit on my buck converter, am still looking for reliable circuit designs and cheap.
