Dc contactor
Williesiddons
Joined Mar 26, 2022
9
I have a motor powered by 5 x 12volt 18 amp batteries, it has a dc contactor in the circuit and a controller for the throttle, would someone please be able to draw me a diagram of how the circuit should be along with fuses and resistors?
also if the contactor could be broken, what contactor should i but to replace this one, picture to follow5F02E6EF-F927-43C6-A4CD-814B08D4B593.jpeg
Reloadron
Joined Jan 15, 2015
7,501
I want to believe you mean 18 AH (Amp Hour) batteries. Next you do not mention if the batteries are in series (5 * 12 = 60 volts) or parallel which would be 18 AH * 5 = 90 AH battery 12 volts. As to a circuit drawing or schematic there is likely a dozen ways to control a motor speed. You do not even mention the motor application? Less much more information there is no answer to your questions.
Ron
Williesiddons
Joined Mar 26, 2022
9
Ron
The batteries are in series and are powering a go kart, at the moment it the negative heads from battery straight into a controller then off to the motor and the positive heads from the battery to a contactor, then the positive from the controller heads to the contactor too and then off to their motor, the throttle is connected to the controller but this doesn’t seem to work
Reloadron
Joined Jan 15, 2015
7,501
So the contactor is switching about 60 volts. I am not sure of the contactor coil voltage. Also not sure of the motor's current? Less a good manual with a schematic it's hard to say what the control circuit looks like. When power is applied to the contactor coil there should be a pronounced audible click sound.
Ron
Williesiddons
Joined Mar 26, 2022
9
Ron
Do u know where I could get a new dc contactor from that would be adequate for 64 volts or have an image of what I need
shortbus
Joined Sep 30, 2009
10,045
Reloadron
Joined Jan 15, 2015
7,501
Depends, they make two types of those solenoids, continuous and momentary use. Most starter solenoids in a car are for momentary use. And now that I think of it do they even use them now days?
https://www.elreg.com/blog/continuo...ter-solenoids-why-they-arent-interchangeable/
That would be true. :) Good point, I always thought as them as intermittent or continuous duty. Continuous duty being for example an electric bike or golf carts for a few examples. Now that I think about it I really don't know what cars use these days? :)
Ron
shortbus
Joined Sep 30, 2009
10,045
Most auto's now have the solenoid internal to the starter.
The service manual often says, 'not serviceable'!
Yeah, the Ford and Chrysler cars used the solenoid switch because they used a inertial type Bendix drive on the starters, one that pulled the starter gear in on the movement of the motor shaft. Where GM used the starter solenoid built on to the motor to engage the gear by a lever and power to the motor when the ignition called for it.
