Data sheet or pinout, please ?
22,082
It does not look like a standard part or part number. Best guess is that it is an OEM part with an in-house label. That probably means no public information or datasheet.
Externet
Joined Nov 29, 2005
2,635
Thanks again, Alec_t
Can you share/teach your search skills for that IC ? Yes, it is a regulator on a printer/scanner PCB.
If you are in the mood, another : :rolleyes:
part number 386120 by Naritoshi, TO252
22,082
I just Googled 00CC0W. It's the first hit. No such luck with the 386120 though.
Results will run the spectrum from being the top hit, to slightly buried, to deeply burried, to pure unobtainim. Like the advice given to Homework Help Posters, you should at least try before asking so you can eliminate cases 1 & 2.
