Data acquisition from a Photovoltaic panel
athcerr
Joined Jun 11, 2021
22
hi ath,
The effective series resistance of the ACS-5 is about 1.2milliOhms, ref image from datasheet,
So a 50% bypass resistor would also be 1.2milliOhm .
That is approx 225mm of 2mmDia Cu wire. ref image.
IF you decide this method I could advise on its construction.
E
If it's gonna work, why not
Thank you so much,
So I have to connect the copper wire to the positive and negative terminals of the ACS712?
ericgibbs
Joined Jan 29, 2010
21,567
hi ath,
If your ACS module is like this image, the two way terminal block has the main in and out wires from the Solar panel to the Load.
Connect the bypass shunt wire in parallel with those two wires on the terminal block
When you get the correct length of shunt wire that gives a 50% current reading from the ACS, let me know.
E
athcerr
Joined Jun 11, 2021
22
Thanks for your help
I am going to get the ACS712 and I will make the circuit.
In figure 3 you mentioned the value of Rload = 8.9ohm, why this value? or did you choose it randomly?
I have considered connecting a rheostat as being a load, it will allow me to vary the resistance value to draw the characteristic curve I (V).
hi ath,
E
bassbindevil
Joined Jan 23, 2014
924
I've heard that the hall effect current sensors can have an offset that has to be zeroed out. That could be inconvenient. Maybe an ACS725 would perform better.
Another possible gotcha if you're looking for accuracy: microcontroller ADCs aren't necessarily perfect, maybe more so if you have a clone Arduino made with a counterfeit Atmega chip.
Consider using an external ADC like the ADS1115 to read the panel voltage and shunt voltage.
assonia
Joined Jun 17, 2021
hi ath,
E
Hi, here I have a work which consists in measuring a current going from 0 to 10A,
Can I use a pewter wire instead of copper??
ericgibbs
Joined Jan 29, 2010
21,567
hi assonia,
I would use a length of that wire, say about 24cms long as a starting length.
Check the the current shown by the ACS module, then adjust the wire length in order give the required current on the ACS.
E
assonia
Joined Jun 17, 2021
salut assonia,
J'utiliserais une longueur de ce fil, disons environ 24 cm de long comme longueur de départ.
Vérifiez le courant affiché par le module ACS, puis ajustez la longueur du fil afin de donner le courant requis sur l'ACS.
E
[/CITATION]
Je prévois en fait d'utiliser une autre méthode (je n'ai pas l'ACS) qui a été proposée par : https://www.instructables.com/DIY-Current-Sensor-for-Arduino/
J'avais le choix entre l'étain et le cuivre, j'ai choisi l'étain car il ne demande pas une grande longueur mais je ne suis pas sûr qu'il puisse supporter l'intensité du courant qui va être imposé (10A)
Mod:Translation.E
I'm actually planning to use another method (I don't have ACS) which was suggested by: https://www.instructables.com/DIY-Current-Sensor-for-Arduino/
I had the choice between tin and copper, I chose tin because it does not require a great length but I am not sure that it can withstand the intensity of the current that will be imposed (10A )
tautech
Joined Oct 8, 2019
507
actually I plan to use another method (I don't have the ACS) which was proposed by
I had the choice between ethan and copper, I chose ethan because it doesn't need a long length but I'm not sure if it can withstand the current that will be imposed on it.
Constantan is the proper wire for shunts and if you need more current handling you run several stands in parallel. You can't solder the stuff so you must use a compression joint.
