Hi
I am new on here and come seeking some advice (have posted this in both the general and automotive sections)
Using single-throw switches (like this https://www.carbuildersolutions.com/uk/black-billet-aluminium-switch-fan - available as single- or double-pole, momentary or latched) I want to achieve two things for a customised car dashboard:
1. Replicate a two-position switch;
so from off, press on, switches on one circuit, press again, switches on a second circuit, press again, switches off
(for two-speed fan and two-speed wipers: off - slow - fast - off and headlights: off - side - main - off)
2. Also, alongside the lights switch, a momentary switch where, if main lights are off (ie off or sides on), press to flash and if main lights are on, it’ll toggle between full and dipped beam.
In each case, there is a relay between these switches and the actual devices, so we’re dealing with 12V and low currents.
How would you suggest this can easily be achieved?
