Should I still use a 2N7002 instead of the big mosfet to switch on the 5v circuit only at dusk? And run 12v directly to the LEDs and LM393?Q2 is not drawn correctly on the schematic.
A resistor is required between pin6 of the ATtiny and the base of Q1.
Why on the image of the pcb does it shows a TO263-2 for Q2?
I had that IRF9Z shown as an NMOS somehow.. maybe I mirrored it at some point. So back to my question in #322. Do you think I should proceed with that plan, but use a BS250?A 2N7002 is the wrong type, requires a P channel like a BS250.
Let me think about that... My brain is fried LOLThe only reason I see for Q2 is to save battery current, which you stated wasn't an issue.
Why not use the output of the LM393 to trigger the ATtiny ?
So, connect pin 1 from the LM393 to a digital pin on the attiny. A WHILE statement would keep the LEDs off when pin is LOW, otherwise the code would run.... read PIR and run the light sequence or not... Is that the idea?The only reason I see for Q2 is to save battery current, which you stated wasn't an issue.
Yes! Good idea. I've been looking at this too long and that never entered my mind. Thx!!Use the BS250 to power the 78L05 but leave U2 connected as is.
The BS250 is available in smt.
Hi Eric. I explained it on the earlier post of my latest schematic. I still plan to use that approach, but it will take me time to fully understand it and to get it implemented and tested. However, I need working boards with the hysteresis and other circuit improvements now. I expect to utilize the ADC, eliminate the LM393 and it's resistors by spring time.hi john,
I am puzzled why you have reverted to the earlier over complex design in using LM393 instead of the ADC input and the MOSFET where a simple reverse voltage diode would work the same, also I have written sketches for the Nano/Tiny which have been to show to work OK.????
I was planning (brainstorming) last night about using the other comparitor to monitor battery voltage level and have pin 7 trigger a rapid blink sequence on the attiny when voltage fell below 11v. A heads up for needing to recharge the battery.Need to use the other of the LM393 to trigger the ATtiny because of the 12 volts on the LM393 exceeds the input voltage of the ATtiny.
Connect pin5 to pin1 and pin6 to pin2.
Connect pin7 to the digital input of the tiny and enable a pull-up on that pin.
I think so... maybe just preference, but I would like the entire 5v circuit to be de energized during daylight hours. I hope I understood your question...Is there really a need to activate the 5volt regulator?
Eliminating the BS250.
AWESOME!! Moving forward. Can I post my PCB when done for a quick review before I send the gerber files to JLCPCB?Looks good.
The 78L05 draws 5mA with no load.I think so... maybe just preference, but I would like the entire 5v circuit to be de energized during daylight hours. I hope I understood your question...
