Dark sensor circuit using LM393 question.... unstable OFF/ON... flickering
LesJones
Joined Jan 8, 2017
4,541
You only know the variation betweens samples of the LDRs thay you have. You need to get samples of the LDR at the lower and upper limits of their specification. From Eric's calculation your samples must be closer together than the limits of the specification.
Les
johnaustinkaty
Joined Jul 16, 2021
284
Les
I understand. I will be continuing to test and track when unit is powered on at dusk. Over time, I can make slight adjustments to R7 as may be preferred.
ericgibbs
Joined Jan 29, 2010
21,567
hi,
I would consider both tests, it will give you confidence in knowing it will work at the High and Low temperatures.
For sure, some of your clients will ask the question.
E
johnaustinkaty
Joined Jul 16, 2021
284
FYI, I added a fourth light to the test group last evening. They all came on within a ten minute period from 5:58pm to 6:08pm, which are ideal light levels at dusk for this application. All chatter is gone now of course. I'm ready to order updated boards, the 470k and 15k SMT resistors and capacitors. I already have all other parts. If anyone is interested in reviewing/checking my board before I order them (for a fee of course), please PM me. Thx again all !
johnaustinkaty
Joined Jul 16, 2021
284
Can someone check my traces on my PCB to make sure I did not miss anything. I have attached a .pdf with the schematic and PCB image. I want to order boards, but need a second set of eyes before I do.... don't ask me how I know :oops:
Thx
John
eetech00
Joined Jun 8, 2013
4,724
Do you mean stability overall? Or, just the dark sensor circuit specifically?
LDR's are temperature sensitive and the resistance will vary with temperature.
The datasheet doesn't show a graph of temp vs resistance. It's possible that the performance of each units will vary.
More expensive LDRs minimize temperature effects.
johnaustinkaty
Joined Jul 16, 2021
284
Dark sensor specifically. Can you tell me approx how much resistance could be expected due to temp swings between 32F and 90F? 1k, 50 k ???
eetech00
Joined Jun 8, 2013
4,724
You mentioned an "LED flash" at startup.
Did you ensure the pin5 of ATiny is not pulled up internally? If it is, disable the internal pull-up resistor, then use a pull down resistor to pull-down LDD-700 pin3 so it is disabled at power on.
johnaustinkaty
Joined Jul 16, 2021
284
Yes, R10 (1k) resistor has been added to my board. Thx
eetech00
Joined Jun 8, 2013
4,724
Then you should re-test without the 1-sec delay. It probably doesn't need the delay now.
But be sure the internal pull-up is disabled. Typically, they are disabled at power-up, then automatically enabled afterwards.
So even disabled, they will behave as "disconnected" until the micro-controller initializes. Disabling it and using an external resistor ensures LDD-300 dim pin will be pulled down.
johnaustinkaty
Joined Jul 16, 2021
284
I had neglected to add the 1k resistor that was shown on the circuit that was provided to me on this thread (pins 5,6 & 7). It was on my schematic, but not on my board. It is actually R5 (not R10). I have also connected pin 6 to pin 2 on the LM393 (not shown on this PCB)
ericgibbs
Joined Jan 29, 2010
21,567
hi john,
Did you do those operating temperature tests I recommended in post #105?.
Without knowing the result of those simple checks, it would not be wise to finalise the PCB track design.
E
johnaustinkaty
Joined Jul 16, 2021
284
hi john,
E
I haven't yet. I will do that today. These temperature tests are for the overall function of the light and not necessarily the dark sensor, right? Or, should I plan the test at dusk also like I've been doing?
Nevermind. I revisited post #105
Thx
ericgibbs
Joined Jan 29, 2010
21,567
hi john,
Just ordered 10 off LDR's of that type, due for delivery this weekend.
I will do some Temperature and Lux tests, let you know the results.
E
