Dangers of carbon rod resistors
-live wire-
Joined Dec 22, 2017
959
I have taken apart a pencil to get the graphite inside of it. My goal is to get it to glow red and be really hot. I am using a 31V 2.5A max power supply (an old printer charger). I am confident that it will work, but I am concerned about the safety. As long as there are no really bright arcs or anything, is there any danger? I head that they can emit harmful UV light. If it is not really bright but glowing red, is this a concern? Please let me know of any dangers.
OBW0549
Joined Mar 2, 2015
3,565
A carbon arc will emit copious amounts of UV radiation; a carbon rod glowing red due to resistive heating, however, will not.
Just take care you don't burn your house down.
-live wire-
Joined Dec 22, 2017
959
So there are absolutely no dangers if it is not really bright, aside from the extreme heat? Also, how would you block the UV radiation so that it is not a danger if you wanted to make arcs but be safe?
cmartinez
Joined Jan 17, 2007
8,898
Ordinary glass is opaque to the most harmful spectrum of UV radiation. But to generate an arc, you normally require voltages much higher than the 31V you've just mentioned... in the order of several thousand, as a matter of fact.
cmartinez
Joined Jan 17, 2007
8,898
So regular glass glasses are enough? I thought you needed special welding glasses to filter all the harmful light out.
Oh yes... I was only talking about the UV radiation. But an intense graphite white-light arc emits light in all the visible spectrum, as well as IR and UV. As a matter of fact, they also emit radio frequencies, and are banned by the FCC for use as a source of illumination due to their jamming effect on communications.
So yes, treat such arc just as you treat a welder's arc, using appropriate filtering glass.
-live wire-
Joined Dec 22, 2017
959
Where could I get such filtering glass? And is it necessary if it is not making bright arcs, but being used as a resistor? I just want to make sure I am aware of all the dangers and can prevent any possible harm.
-live wire-
Joined Dec 22, 2017
959
Cheap and good? I want to make sure it will work for my purposes and filter everything that needs to be filtered out.
When I was a kid--early 40's?--I got arc lights with my mother's iron as a ballast and two carbon rods from D cells. I'm lucky to have survived childhood.
cmartinez
Joined Jan 17, 2007
8,898
Yeap... it's cheap and good... and most importantly, safe. At least for your face and eyesight... but be very extra absolutely careful if you're planning on experimenting with high voltages... I can't stress that enough.
-live wire-
Joined Dec 22, 2017
959
There is a circuit breaker that triggers when there is a lot of overcurrent for a second or two. You have to unplug and replug it to get it to work.
Reloadron
Joined Jan 15, 2015
7,980
I had all but forgotten taking apart D cells (late 1950s) that were dead and removing the carbon rods and building carbon arc lamps. Yeah, more than once I have looked back and wondered why I survived those formative years. :)
My friends father had a print shop and the rage was an AB Dick 360 offset press. The plates were burned using huge carbon arc lamps. Serious bright stuff. Safety glasses what? :)
Ron
