Hello everyone, first time here and very new to forums. Can anyone ID the attached component marked D9D or D9_D. It is a flat three legged component located in the middle left side of the photo.
This IC board is part of a 20 year old talking toy that I don't have a schematic for.
When I received the toy it was not working and missing off the board completely a 8059S (Q3) transistor and connecting to the Q3, a 100 ohm (101) resistor located in upper left corner of photo.
I replaced the missing transistor and resistor and the toy started working and talking, but with very reduced specker volume. I replaced the speaker with a known good speacker and still with very reduced volume.
When looking around the board, I can't see any additional physical damage, but I did feel a lot heat coming off of the D9D marked component. It's very hot to the touch.
I know its not much information to go on, but what do ya'll think about the heated D9D component, is it causing the reduced volume and just what is the D9D anyway?
Google says D9D is an obsolete Russian diode. Help if you can.
