D-Sub schematic design
AnalogKid
Joined Aug 1, 2013
12,243
Look in the library to see if the D-sub connector is there. If it is, pull it into a schematic. If it isn't, create it and pull it into a schematic.
Create a symbol for the Hall sensor and pull it into the schematic.
Connect the two components with signal nets.
Export the schematic to the pc board layout program.
Define the pc board shape.
Route the connections.
ak
Rava
Joined Dec 6, 2017
10
ak
I have both components, I just don't know how I'm supposed to connect them and which pin is connected to where?
AnalogKid
Joined Aug 1, 2013
12,243
Which pin depends on the components and what you want them to do.
Why do you want to connect them?
What are you trying to achieve?
What does the D-sub connect to?
You have given us absolutely zero information about your components and your circuit. What kind of response do you expect?
Hall sensor manufacturer - part number - data sheet
ak
