D flip flop verilog code
vead
Joined Nov 24, 2011
629
I want to write verilog code throw the function table given below
D C Q Qn
0 0 Q Qn
1 ↑ 1 0
0 1 Q Qn
1 ↓ Q Qn
where D, c are input and Q and Qn are output
I am trying to write code
syncronous D flip flop with positive edge
Rich (BB code):
 module D_flop (D,C,Q,Qn);
           Input D;
           input C;
           output Q;
           output Qn;
           Reg Q;
           Reg Qn;
           always @(posedge clk)
           initial
Don't know how to write next code
Brownout
Joined Jan 10, 2012
2,390
Don't use "initial" for this code. It's only good for testbench coding. now, you have an "always" block, but you need "begin" and "end" statements. within those two statements is where your flip-flop will get its functionality. You'll use basic assignmnet statements for this eg. Q <= D, and so forth.
kubeek
Joined Sep 20, 2005
5,796
You are missing a few possibilities in that table, for example what happens when this happens on the inputs
D C Q Qn
0 ↑
vead
Joined Nov 24, 2011
629
D C Q Qn
0 ↑
ok you mean like this
D C Q Qn
0 0 Q Qn
1 ↑ 1 0
0 1 Q Qn
0 ↑ 0 1
1 ↓ Q Qn
vead
Joined Nov 24, 2011
629
now the code will be
Rich (BB code):
Input D; input C;
 output Q;
output Qn;
Reg Q;
Reg Qn;
begin
If( ? )
Q <=....
else
Q <=......?
end
End module
how to complete code
33,111
Have you worked through any basic Verilog tutorials? This is usually one of the basic circuits that is covered.
Brownout
Joined Jan 10, 2012
2,390
Rich (BB code):
Input D; input C;
 output Q;
output Qn;
Reg Q;
Reg Qn;
begin
If( ? )
Q <=....
else
Q <=......?
end
End module
Between the "begin" and "end" statements for the always block, the assignments are already sensitive to the rising edge of the clock signal. So, now all you need to do is just make the assignments straight from your table. The if(?) is not needed.
vead
Joined Nov 24, 2011
629
ok I try to write code
Rich (BB code):
 Input D;
 input C;
 output Q;
 output Qn;
 Reg Q;
 Reg Qn;
 begin
 If( clock raise )
 Q <= 1'bo, 0'b1;
 else
 Q <= Q
 end
 End module
kubeek
Joined Sep 20, 2005
5,796
how about this
Rich (BB code):
 Input D;
 input C;
 output Q;
 output Qn;
 Reg Q;
 Reg Qn;
 always @(posedge C)
 begin
 Q <= D;
 Qn <= !D;
 end
 End module
vead
Joined Nov 24, 2011
629
how about this
Rich (BB code):
 Input D;
 input C;
 output Q;
 output Qn;
 Reg Q;
 Reg Qn;
 always @(posedge C)
 begin
 Q <= D;
 Qn <= !D;
 end
 End module
I think I have to write binary statement like if clock is raise then store the value 0 , 1 otherwise no change
kubeek
Joined Sep 20, 2005
5,796
no you don´t. The raising clock edge is taken care of by the "always @(posedge C)" so the block is executed anytime there is positive edge on wire C.
Now since your fuction table assigns 0 to Q when D is 0 and 1 when D is 1 it is as simple as assigning the value of
D to Q and the negative value to Qn: Q <= D;
Because Q and Qn are register types, they will remeber their value until you assign a new one.
vead
Joined Nov 24, 2011
629
I have complied that code on quartus software but there is some error
vead
Joined Nov 24, 2011
629
Some error, are you serious? Have you thought about telling us WHAT that error was?
Error (10170): Verilog HDL syntax error at D_flop.v(13) near text "module"; expecting ".", or an identifier ("module" is a reserved keyword ), or "(", or "["Error: Quartus II Full Compilation was unsuccessful. 3 errors, 0 warnings
kubeek
Joined Sep 20, 2005
5,796
obviously you are posting here just one error out of three. Please post all you´ve got, just like tshuck askes you to do.
