custom IR line array sensor development
Bernard
Joined Aug 7, 2008
5,784
Back to post # 9 except am using a short strip of cardboard 2 pinholes crosswise spaced .1" in center.
Tx tight fit to strip with a drop of quick setting epoxy on Tx, adjusted for maximum output, taped in place to cure. Rx for testing is TEMT1020, SMD, gull wing, but will switch to TEMT1000, inverted gull wing for easier mounting. I'll try to come up with a sketch soon. Had second covid shot today will see what tomorrow brings to this 94 year old.
zazas321
Joined Nov 29, 2015
936
Oh wow hold on tight there! And thanks for the answer
zazas321
Joined Nov 29, 2015
936
Okay. Back here we have some new cases recorded from African covid. Apparently, this covid is immune to the vaccine that we currently use. :oops:
zazas321
Joined Nov 29, 2015
936
No fixed deadline. Currently we use whatever sensors we had available which are:
https://www3.panasonic.biz/ac/ae/search_num/index.jsp?c=detail&part_no=CX-421
They work, but it is not convenient since they only operate in a very narrow beam and operators need to ensure that they put a hand exactly below the sensor to toggle it which is not efficient/convenient.
We also have some Emmiters :https://www.digikey.com/en/products/detail/everlight-electronics-co-ltd/IR333-A/2675571
And receivers : https://www.digikey.com/en/products/detail/osram-opto-semiconductors-inc/SFH-203-FA/607284
I have got them from the local shop just for testing, now just realised that receiver peak wavelength is 900nm while the emmiter is 940nm. I hope that I can get atleast some sort of results out of that
Bernard
Joined Aug 7, 2008
5,784
We have an IR curtain. 6 pairs, TX- VSLY5850, Rx- TEMT1000. A hand can move about any where within the 28 cm X 40 cm opening and receive one output-- but if only a finger is waved within the opening there can be multiple outputs. Most of this problem could be mitigated by adding a pulse stretcher or retrigerable monostable multivibrator. ( spell check doesn't like my spelling of these words ) maybe up to one or two seconds. I will be back late Monday
Bernard
Joined Aug 7, 2008
5,784
With just a short time available today, I lashed up a pulse stretcher with : 1N4148 diode, 1M pot, 10 uF cap., & CD74HC14 schmitt trigger. @ 100k, pulse delayed about 1 second allowing only a single pulse while waving a finger in opening but not allowing retrieval of 2 objects without detection.
zazas321
Joined Nov 29, 2015
936
Thanks for the information you have shared. Can you clarify what do you mean by saying not allowing retrieval of 2 objects without detection?
Bernard
Joined Aug 7, 2008
5,784
Maybe the delay should be adjustable for the system shake down as too short a delay might allow
extraneous hits & too long of a delay might allow more than one fetch per output pulse.
Bernard
Joined Aug 7, 2008
5,784
Here is some notes to chew on. I had a MRI this AM + iodine introvenious infusion- not supposed to
have serious side effects so why do I feel rotten?
Ask away and maybe I can come up with some answers.
Printer missed the +5 V connections on top of drawing.
+ 5V
___________________________________________________________________________________________________________
Sensacell
Joined Jun 19, 2012
3,784
Have you tried turning on an incandescent lamp near this thing?- you will be horrified by the results, but it's an essential thing to try.
This is why commercial light curtains never use DC light sources.
Bernard
Joined Aug 7, 2008
5,784
Thanks for the heads up Sensacell. I placed a 72 W incandescent light 2 ft facing sensors & shure enough one of detectors was over sensitive until load R was changed from 6k8 to 4k7. Back to normal operation.
Sensacell
Joined Jun 19, 2012
3,784
God help you if you ever operate this near a window!
Bernard
Joined Aug 7, 2008
5,784
I must of had help . IR curtain on a table 4 ft. from sliding glass door facing South, sun at bottom of door, 11 AM, 33 deg N.
@ 90 deg. no problem.
Emitters facing door, no problem.
Sensors facing door, door open; two sensors of 6 over ridden.
Sensors facing door, door closed; one sensor over ridden.
zazas321
Joined Nov 29, 2015
936
Amazing help thanks.
I still have these schematics:
Perhaps you could show me a final schematic of your IR curtain working prototype?
Bernard
Joined Aug 7, 2008
5,784
I think that you have it all in post # 38 & # 53 & #60.
Post # 38 shows either 7430 or 74HC30 but my protype, because I had one, uses a CD4068BE , different pinout and has both NAND & AND outputs. On solderless bread board with a LED & driver, post # 53,
on NAND output, tied all inputs hi & one at a time varied input V to check trip point between 0 & 1.
Average about 3.3 V. On inputs , adjusted R2 's so V was about .5V higher than trip point. It is a balancing act so that light leakage V out does not = a hi and normal light does = a hi.
An other possibility is to use a comparator on each photo transistor output allowing trip point to be determined, probably one common fixed V. Only need 2 IC's, 4 / IC.
