Hi. Why 3 curtains? The number of sensors/curtains does not matter. The only thing that does matter is that I have absolutely no blind spots across the whole 2D space (300x400mm). The box will be 3D but as long as 2D space is fully covered, I do not need to worry about the 3rd axis since it should be impossible for the person to put his hand through the hole without triggering the sensorsI'm slightly confused, is there to be 3 curtains or just 1 ?
Are there to be any hands smaller than 4 cm ?
OK- just one curtain 300 mm X 400 mm.
Please make sure tell me what are your results. Thanks in advanceThe 10 each of items in post # 18 should be here next week. Will see if is possible to put all Tx on one side & Rx on other.
Thats great. Could you tell me what Emmiter and what receiver have you used?I get excellent results using a single emitter and receiver diode in an IR reflectance circuit.
The diodes are mounted side by side and the receiver diode picks up the IR reflected from a hand when it enters the box.
Similar circuit as those "Avoidance Sensors".
Emitter is a Vishay TSAL6100, receiver a Vishay BVP10NF.Could you tell me what Emitter and what receiver have you used?
zazas321 I don't think you need a light curtain for this project. The circuit I posted in #26 should meet your requirements with that single circuit. I would highly suggest that you try it out before committing to a light curtain.
No. That was just my poor representation of a human hand entering the box in the middle. However, a human hand might go in the box in any way possible.I was under the impression that the front of the box has a hole where you put your hand through like in the sketch?
Thanks for clarifying. I am still not certain about this part of the circuit:U1- Tx, transmitter, emitter, VSLY 5850
U2- Rx, receiver, IR detector, SFH 313FA
U3, 8 input NAND, one input for each U1-U2 pair. Output from U2's is normally hi,; if all inputs are hi
then U3 output is lo. If any input is blocked then U3 goes hi. Output hi's are counted but how they are counted has not been specified. U4 just one example of a LED output.
U4 has 6 inverters in the IC, 74HC4049. For different supply V , then can use 4049.
If more than 8 inputs are required any number can be built from NAND-NOR- NAND IC's.
To select spacing, might try placing strings across a box & see if you can insert a hand without touching a string ?
R2's are selected to be as low as possible but give at least 4 V out when U2 is illuminated then use highest value for all 8 -10 beams.
