Current Transformer Help
Tahsina Hossain
Joined Jan 16, 2015
50
Hi there,
I need to use a current sensor CT-HX 3_50 in order to sense current of my inverter. I have never used a current sensor before so before going to a real circuit I am developing some test circuits. I know that the CT can go upto 3+-9 Amps and also that 4V is equivalent to 3 Amp? Now I am worried about the load, How to set it up? I mean I have no rheostat that goes up to 3 Amp. Also, I am not sure if I am constructing the circuit right. Attached are the circuit diagram and also the datasheets.
Please help.
Bests,
Tahsina
MikeML
5,444
The whole advantage of spending the big bucks for the HX module is that it should be calibrated out of the box, so shouldn't really need testing...
For a wiring checkout, why not use it to measure the current drawn from the DC supply between the supply and the two DC-to-DC converters?
Tahsina Hossain
Joined Jan 16, 2015
50
Hi MikeML,
Thanks a lot for your reply. when you say 'measure the current drawn from the DC supply between the supply and the two DC-to-DC converters' do you mean I can just directly measure the current from there without adding any kind of impedance? Sorry if this is a stupid question, I am just trying to understand how to build the circuit so that I don't blow up my current transducer.
Also, I am trying to set up the test circuit as a part of my bigger project of load sensing and changing the switching frequency of the inverter based on the load current level and I will implement a MSP430 to do the coding and try to read current transducer output through MSP430.
Thanks again!
MikeML
5,444
The current sensor will measure the current flowing into pin5 and out of pin6 (i.e. through the sensor). I suggest temporarily using the current drawn by the two step-up converters as the test current.
Hang a scope on pin4 (scope gnd on pin2) to see what the sensor outputs. Any additional load you hang across the +15V to -15V side of the step-up converters should increase the current sensor reading...
Tahsina Hossain
Joined Jan 16, 2015
50
Thanks a lot Mike, attached is the new diagram, Can you kindly check if I got your awesome suggestion right.
I highly appreciate your time and help!!
