Current sources
dsuperbad
Joined Nov 3, 2013
5
I have question regarding examples from book art of electronics - i can't figure it out how to calculate and what happens in this circuits. Are points A and B on ground voltage because of point B or are they on point A because of voltage divider ? figures are in attachment
Jony130
Joined Feb 17, 2009
5,600
33,218
For the Howland current source, you can analyze it by naming the output voltage of the opamp Vo. Then, given Vo and Vin (plus R1 and R4), find the voltage at the inverting input (Point A). After than, given Vo and Iload (plus R2, R3, and Rload), find the voltage at the non-inverting input (Point B). Now apply the assumption that the opamp is operating in its linear region and therefore the voltage difference between the two inputs is negligible. You can then solve for the load current and should find that it is a function of the input voltage and the four resistors, but that it is NOT a function of the load resistance.
