Current sourced/sinked by an Opamp
andrew74
Joined Jul 25, 2022
263
Hi! I have a theoretical doubt that will probably amuse many of you.
I am thinking of an opamp that amplifies an input voltage, producing, for example, 10V.
If I connect a 70ohm resistor (to ground) to the output of the opamp, I would end up with about 150mA on the resistor.
Without considering 1.5W on the resistor, not the point of the question, I wonder if that 150mA would damage the opamp.
The current would come from the feedback branch, however, if the output impedance of the ideal opamp is low (say 0), why is the current flowing into the resistor and not into the opamp? Since the current always chooses the path of least resistance.
EDIT:
I have the analog PWM output of an Arduino that goes from 0 to 5V (depending on how I decide via software the signal .. there is a whole PID control etc) and I need a stage that amplifies that voltage to, say, 0-10V.
It is important to isolate the load of a few ohms from the microcontroller because of the currents that might flow. I had thought of a buffer, but still I need amplification as well, so I think a single opamp with feedback (feedback resistor etc) is sufficient. A non-inverting opamp also acts as a buffer .. right?
If my reasoning is correct, all that's left is to choose this amplifier, and back to the main question we were discussing.
Thanks to @ericgibbs and @Ian0 for reminding me to update the post with all the available information I had
Ian0
Joined Aug 7, 2020
13,236
Check your op-amp datasheet. It will specify the maximum output current, which is generally a few tens of milliamperes. Any load requiring more output current will cause the output stage to current-limit.
It is unlikely that the current would come via the feedback resistors. If so, it would have to come from whatever is driving the input.
WBahn
Joined Mar 31, 2012
33,086
A schematic of the circuit you are talking about would sure help make for a more coherent discussion. Without it, there's no way to talk meaningfully about what current is going to or coming from where.
Forget this "current always chooses the path of least resistance" crap. That is a gross oversimplification. Current will flow through all paths if there is a voltage across them and finite resistance along them.
andrew74
Joined Jul 25, 2022
263
Let's assume the op777 .. which parameter indicates the maximum output current?
I can't find it in the tables
LowQCab
Joined Nov 6, 2012
5,101
You can think of an Op-Amp as having a Resistor built-into it's Output.
The only reason why the Op-Amp has an "effective" low Output "Impedance"
is because of extremely high Gain in combination with Negative-Feedback.
With a heavy Load, and maybe only 1-Volt of Output-Voltage,
the Output-Stage may be approaching one of the Power-Supply-Rails,
this means that all that Voltage-Drop is INSIDE the Chip,
generating tremendous amounts of HEAT.
The "Open-Loop" Output-Impedance,
and the "Closed-Loop" Output-Impedance,
( which may only "appear-to-be" ~0.5-Ohms ),
are two vastly different things.
OP777.png.
WBahn
Joined Mar 31, 2012
33,086
There are two sets of specs, one for a supply voltage of 5 V and one for ±15 V (so 30 V total). Since you mentioned 10 V output, let's use the latter:
There's a typo and it says "Output Circuit" where it means "Output Current".
If your total supply voltage is less than 30 V, the maximum output current will be less than 30 mA. At 5 V it is only 10 mA.
This opamp is not suitable for driving your 70 Ω load directly.
LowQCab
Joined Nov 6, 2012
5,101
With a ~70-Ohm Load,
You will not be able to get ~10-Volts of Output,
and the Chip will slowly over-heat until it finally fails.
"" Output Short Circuit
The output of the OP777/OP727/OP747 series amplifier is protected from damage against
accidental shorts to either supply voltage,
provided that the maximum die temperature is not exceeded on a long-term basis
(see Absolute Maximum Rating section).
Current of up to 30 mA does not cause any damage.""
DickCappels
Joined Aug 21, 2008
10,662
Most semiconductor datasheets have little section that looks like this, usually "early" in the datasheet.
It doesn't fully answer your question but tells you how to not kill you op amp.
andrew74
Joined Jul 25, 2022
263
View attachment 292581.
Thanks for your answer.
It is not clear to me what the y-axis "Δoutput voltage" indicates.
LowQCab
Joined Nov 6, 2012
5,101
That Triangle symbol is the Greek-Letter "Delta"
and is commonly used to indicate that the following number
is the "difference" between 2 other numbers.
In this particular case,
the number is the Voltage-Drop between the Power-Supply-Rail, and the Output-Voltage.
The Current at the Output,
times the Voltage-Drop shown in the Graph,
equals the number of Watts of HEAT generated inside the Chip.
andrew74
Joined Jul 25, 2022
263
I this particular case,
Thank you. So if I have 1mA and Vs=+-15V .. the Δoutput voltage=40mV and so 40uW dissipated in the opamp
andrew74
Joined Jul 25, 2022
263
LM675 can source/sink 3A. Make sure that it is properly mounted on a heatsink.
1) Before buying the component, I would like to simulate it. I cannot find the model for LTSpice (or Multisim) of the LM675 ... do you have it?
Maybe I should use one of these two simulators (I don't know what they are) that TI provides?
2) If we there is not the LM675 spice model ... are there alternative opamps that you recommend that I can test via software before buying them?
@crutschow @LowQCab @MrChips @DickCappels @WBahn @Ian0
