Current Measurement - 1 to 10 A Simulation help needed
Alec_t
Joined Sep 17, 2013
15,119
Is this school/college work?
Note that your circuit drives the non-inverting input of the opamp more negative than the opamp's ground terminal. Most opamps don't like that.
mishra87
Joined Jan 17, 2016
1,063
Hi Altec_t,
its not a school/college work.
I mostly open thread for real time application.
Note that your circuit drives the non-inverting input of the opamp more negative than the opamp's ground terminal. - I still do not understand this - why ?
Could you post your schematic ?
Non inverting terminal can be grounded using resistor.
Thanks !!!
mishra87
Joined Jan 17, 2016
1,063
Hi Guys,
Since I am a thread starter,
I should have done some homework before posting a thread.
Now I tried to simulate the attached schematic please verify simulation file with circuit and post your opinion.
Thanks in Advance !!!
