Currently the circuit which is built already for LED (BXRA-56C5300) [datasheet attached] has 1 ohm current limiting resistance which will limit the current drawn by LED to 2.1 A when supply voltage is 24 V. The forward voltage of LED is 21.1 During normal operation max current flowing through it should be 2.1 A . Also the intensity is varied by using transistor in series with LED and resistor [Circuit Attached] . This setup is repeated for 32 such LED parallel connected to one DC 24 V supply .Such in total 64 LEDs are used powered with two different 24 V power supply.
Now the requirement now is to pulse the LED to its max rated current which is 4 A which can be achieved with supplying voltage around 28~29 V .Since this circuit is already built can't make any changes . So in order to achieve this voltage I was thinking of using SLA (car batteries) for this votlage .
I am thinking should I use battery to boost voltage which is supplied by 24V (AC TO DC) converter or use independently powering with SLA with voltage regulated to 28~29V . The requirement is to just pulse the LED with max current so it will glow at max intensity and then run again on regular 24 V supply. But this switching should be digitally controllable . Please let me know if I am missing out .
Thanks!
Thanks!
