Hello All
I have designed the circuit for limiting the current at 100mA, by following the below video's.
I just checked that does the circuit will work when decrease the load resistor to that can draw 1A current. In this case, the NPN transistor that is connected to the power supply is switched ON after few seconds, but it shouldn't be switch ON as per the designed and explained in the below video's.
I was measured the Base, Collector, and Emitter voltages, and the base voltage is lower than the emitter voltage. The measured values are Vb=40V, Vc=48V, Ve=41V. Since the NPN transistor is in the cut-off region as per characteristics and measured values, then, how the transistor is Switched ON. I'm saying it is switched on because I measured emitter current that it is 0.9A almost.
Could you explain why and how the transistor is switched ON, and why current limit circuit is not working?.
Thank you.
Thank you.
