Current limiter with lower power losses
28,322
If you have an electric motor in the hazardous area it must either be internally air purged OR of explosion proof construction. We did that with the gasoline fuel flow system on carburetor test stands, and the motors were totally accepted. The wiring had to be explosion proof as well. ( For those who do not know what "Explosion Proof" means in this context, look it up in the published standards. It is quite boring.)
snoozy
Joined Apr 8, 2022
20
The alternative is intrinsic safety (for small motors). The windings could be encapsulted as well (if possible) or oil filled. There are a lot of options, but all types of protection have their difficulties to apply for certain applications.
What does your current circuit look like? What is current limit set to and what is it limiting at?
The current is about 1.2 A when the MOSFET drives the motor. Basically it is just the motor and a MOSFET that drives it directly from the battery. I measured the voltage and the resistance to calculated it. The limit is at 600 mA for the inductance.
28,322
It seems like the application may be a "sniffer" for a portable gas detector. Our local gas company equips their service folks with those devices to use when a gas leak is suspected. They must somehow be safe because when I had called about a leak possibility the service person turned his sensor on and then almost immediately vacated the building and had me open all the doors to vent it, while he stood with his truck between him and the building. So it did not set off what could have been an explosive mixture.
So for a portable gas sensor there may be safe sized motors available.
That is just a guess on my part. The TS application may be different, we have no clues given.
ci139
Joined Jul 11, 2016
2,033
