Current Limiter For Guitar Pedal Circuit
Camsmit1
Joined Dec 20, 2017
Hi all,
Struggling with a new build that has an in rush current as I turn on the guitar pedal. When I power up the pedal the current rushes up to 210mA but actually stabilises at about 170mA. So would ideally like to limit the current draw of the circuit to 180mA. Maybe a slow start circuit could be useful or a limiter itself?
If anyone has any suggestions for current limiting circuits it would be much appreciated
38,598
That seems like a relatively small surge current, likely due to charging of the filter capacitors.
Why do you want to go to the trouble of limiting the current?
What is the supply voltage?
Camsmit1
Joined Dec 20, 2017
So the supply voltage is 9V. Most power adaptors for guitar pedals are rated to about 150mA/200mA. So I'd like to avoid overdrawing current from the power source if possible.
AnalogKid
Joined Aug 1, 2013
12,199
The current surge is caused by charging up the power input filter and decoupling capacitors in the circuit. This is a very short-term transient, and is not causing *any* stress in the power supply. Even if you powered it up once a minute forever, the supply wouldn't notice.
ak
BobTPH
Joined Jun 5, 2013
11,585
What is the problem you are trying to solve? As others have pointed out, what you are describing does not seem to be a problem.
Bob
