Current flow through NPN transistor to resistor.
benphillips
Joined Mar 29, 2019
10
I have a question about this circuit.
Since electrons flow from negative to positive.
When the points are open, is a there current flowing through the emitter, through the base, to the R1 resistor?
If so, when the points close, does current stop flowing from emitter to base?
benphillips
Joined Mar 29, 2019
10
Thank you. I don't know why I mentioned the electron flow.
If I unplug the collector from the G Terminal, connect a meter from battery postive to the collector, will I have 0V when the points are closed? and have voltage when the points are open?
Ylli
Joined Nov 13, 2015
1,092
Yes, the transistor will be off when the points are closed, and on when the points are open. When the transistor is on, you will see almost the full battery voltage between the + rail and the collector. With the transistor off, you would see zero on the voltmeter if the transistor was perfect - but in reality they have a bit of leakage. So you will see *near* zero.
38,804
Yes, again.
But there may be a small voltage when the points are closed due to leakage current in the transistor.
