I am trying to get hold of pogo pins with cupped heads that will fit the bottom of the GPIO pins of a Raspberry Pi. Ideally like the ones one this board: https://thepihut.com/products/pcie-slot-for-raspberry-pi-5-p02?variant=43225854410947
I've searched all over the web and there are loads of pogo pins for DIP boards with rounded heads but none with cupped heads. I need the pins to spring down to under 10mm, ideally a spring range around 6-12mm would be perfect.
The closest I found was this: https://www.uugear.com/product/cupped-head-pogo-pin-for-big7-usb-hub/
But you also need the tubular holder to attach to the board.
Can anyone help me find where these exist. Would really appreciate it! Thanks.
