CSCR compressor, contactor, relay problem.
Volttrekkie
Joined Jul 27, 2017
63
Hi. I worked on an ice machine today that had a bad contactor and a bad run capacitor. The capacitor measured completely out of range, but no bulging. The contactor would engage but still read 120V pole to pole. Why would the contactor and the run capacitor go out? The start capacitor was fine, I guess because the start relay took it out of circuit. I could not check the compressor because I could not get the back panel off--machine was too close to the wall. Is this common for CSCR motors? Any ideas?
MaxHeadRoom
Joined Jul 18, 2013
30,791
For a compressor contactor it is recommended to go with a Special Purpose Contactor, if not already, this is a type of contactor for HVAC and compressor uses among others and is rated for motorized systems that are constantly cycling.
Max.
