Hi all, hope everyone is doing ok.
I've got a 2002 e-machine e-view 17s old stock CRT (with TECO tube in it , not Samsung) I bought back in December 2024. It worked fine with my retro 486 machine, but when I connected an AMD Athlon XP machine to it and changed the resolution to 1280x768 it worked for 10 minutes, then the picture started shrinking back and forth (with a sorta degaussing sound). I turned it off, connected back to my 486 but the effect was the same: collapsing and then restoring picture. I turned the monitor off. Waited for a while and then turned it on. The picture was gone. It looks like it's getting to the x-ray protection.
- The monitor is very clean inside (it was really a new old stock, so I was the first one who opened it)
- I checked the flyback by placing a small neon lamp against it and when I turn the monitor on the neon lamp glows for a second, I hear the energizing static sound, then neon lamp dims and the high voltage is gone.
- I measured HOT and I can say for sure there is no short between emitter and collector.
- I checked every electrolytic capacitor (in circuit) with GME ESR meter and all of them are just fine
- I checked the voltage regulator and it seems to be ok: the input voltage is showing 10v and the output is 5v. (I have no idea what actual voltage should be there since I didn't manage to find any schematic for it)
- I think I checked B+ (again no schematic) at a positive lead of the couple first filtering capacitor right after transformer output: one of those shows 57v (which is kinda low if it's B+ but I can't imagine what else can it be) and another one is 10v
- I discharged HV anode under the rubber cap ( I guess in this monitor it's not required really but I always do before doing anything) then removed the cap and made sure that it all clean under it (the monitor was sealed in a box and plastic when I bought it so it's very clean inside).
- when it presumably goes to x-ray protection there must be a zener diod somewhere. I found 4 of them on the PCB and couple of them is clearly linked with one of the flyback leads (must be the low voltage leg for x-ray protection I guess) and those zeners are connected to two different ICs (i have no idea what are those, but they don't look like oscillators, still zener might cut the HV by sending 5v to one of those ICs probably)
Now I'm puzzled. It looks like it's going to x-ray protection, but whatever I could guess I checked. Being not experienced in fixing CRTs (this is my third CRT I've opened in my life and the first not working) and not having schematic I'm stuck.
Maybe it's a flyback itself still causing it despite that it's trying to turn on, but something might short inside and this is causing it to shutdown. Maybe something else.
That presumably-B+'s 57v is a concern, but I'm not sure maybe for this monitor 57v for B+ is normal. I checked it when the monitor turns on and even before it shuts the HV down that presumably-B+ remains the same 57v.
I'm just hoping that maybe somebody here could give me a hint what to check next
or maybe someone knows where to get schematic for e-machine e-view crt monitor ?
P.S. But frankly I probably should just take it to the e-waste site and forget about it.
Thanks a lot for reading this,
Sincerely Yours, Eugene Kiselev
