Creepage Calculator for 24VAC
DJ_AA
Joined Aug 6, 2021
502
Hi All
I am working on a PCB, which needs to provide 24VAC to various solenoids.
The max current each solenoid will require is about 0.3A-0.5A, but i would prefer to design for 1A.
On the PCB layout design I believe as its AC power a design would need to incorporate creepage.
Is this required for 24VAC?
Ian0
Joined Aug 7, 2020
13,310
The fact that it is an AC supply is irrelevant.
These are the values from EN60335 which applies to most household electronics.
This is the pollution degree:
Pollution Degree 1: No pollution or only dry, nonconductive pollution occurs. The pollution has no effect.
Pollution Degree 2: Normally only nonconductive pollution occurs. Temporary conductivity caused by condensation is to be expected.
Pollution Degree 3: Conductive pollution or dry nonconductive pollution that becomes conductive due to condensation occurs. To be found in industrial environment or construction sites (harsh environments).
Pollution Degree 4: The pollution generates persistent conductivity caused by conductive dust, rain, or snow.
and the CTI for FR4 board is 175.
DJ_AA
Joined Aug 6, 2021
502
I guess with 24V the spacing will be much lower then 50V,
At moment the spacing between my traces is about 3-5mm.
Ian0
Joined Aug 7, 2020
13,310
You're not allowed to interpolate the table, use the 50V values. Also check whether the voltage is rms or peak, and, obviously, if that standard applies to your product!
So you can make your tracks wider until the spacing gets to 1.1mm
DJ_AA
Joined Aug 6, 2021
502
Yes, it makes sense. This way maximise the current.
Would this spacing be between only 24VAC traces or 24VAC against any other nets?
