creating new component with cir files
Seongwoo Oh 1
Joined Aug 26, 2018
I have a low noise amplifier which has a HEMT as its transistor. (ATF38143). I have been trying to create a component in LT Spice and came across this website.
The page linked here is a .cir file for ATF34143 and it was the closest HEMT I could find.
I copied and pasted the script in a text editor and saved it in the .cir format. Then, I opened it with LT Spice, highlighted the name of the HEMT in the first line of the .cir file to create a new component.
Unfortunately, when I attempt to simulate the circuit, it results in an error. I have tried the same simulation without the user defined HEMT and the result of the simulation appeared reasonable.
I have also tried the .cir file of a different transistor from the same website (linked here) and went through the exact same steps to create a component corresponding to the .cir file. It worked smoothly.
Could someone take a look at the content of the cir file for the ATF34143 transistor shown on the website and point out what's wrong with it? Given that I was able to create a new component with a different .cir file, I am certain what's in the .cir file for ATF34143 is wrong.
I have also attached my asc file contaning the circuit I was trying to test.
Alec_t
Joined Sep 17, 2013
15,171
Here's the model :-
*ATF-34143 packaged FET model
.SUBCKT ATF34143 16 14 15
RR2 2 1 0.1
RR9 4 3 0.1
RR5 1 5 0.1
LL2 5 SOURCE 0.1nH
LL7 SOURCE 7 0.1nH
LL6 SOURCE 8 0.1nH
RR6 8 2 0.1
RR7 7 2 0.1
RR8 DRAIN 9 0.1
LL5 9 11 0.1nH
LL8 2 15 0.05nH
LL10 15 1 0.1nH
LL1 14 4 0.8nH
LL9 11 16 0.6nH
CC3 11 2 0.15e-12
CC4 1 4 0.15e-12
LL4 3 GATE 0.1nH
*CALL DIE MODEL
XDIE DRAIN GATE SOURCE BATF34143
.ENDS
**** GaAs MESFET MODEL PARAMETERS
.SUBCKT ATF34 D G S
.MODEL BATF34143 GASFET ( LEVEL=2, Vto=-0.95, Beta=0.24, Lambda=0.09, Alpha=4,
+ B=0.8, Tnom=27, Vbi=0.7, Delta=0.2, Cgs=0.8 pF,
+ Cgd=0.16 pF, Rd=0.25, Rg=1, Rs=0.125, Cds=0.04 pF,
+ Is=1 nA, P=0.65)
.ENDS
The ATF34143 model calls the BATF34143 GASFET model. Unfortunately LTspice doesn't recognise the GASFET type and its listed parameters.
eetech00
Joined Jun 8, 2013
4,751
Hi
Try model attached.
Be sure to change mesfet symbol "prefix" attribute from Z to X (if it isn't already X).
eT
