creating footpring according to rf connector datasheet 32K243-40ML5
yef smith
Joined Aug 2, 2020
1,481
Hello,I need to create three pads to accomidate the RF conector.
two pads fro the crews and one pad for the inner RF pin.
few questions.
1. how can I know to which board width this component can handle?
2.according to the datasheet what is the inner pin pad width and length I should use?
3.I want the crews to be in tight fit so the connector woulg be stable in the board.
What pad diameter I should use?
Thanks.
https://products.rosenberger.com/_ocassets/db/32K243-40ML5.pdf
liaifat85
Joined Sep 12, 2023
200
The datasheet specifies that this SMA connector is suitable for a PCB thickness of max 3 mm. Any board with a thickness less than or equal to 3 mm is compatible.
