creating air condioner remote with an microcontroller
yef smith
Joined Aug 2, 2020
1,477
Hello there is an air conditioner of my friends house whose landlord controls it by remote (some functions are disables)
I would like to communivate with this air condioner and conrol these dissables options :)
I have esp8266 controller , EFR32 EVM.
There are some questions:
1.Where can i find the Infra red manual commands of the air conditioner?
2.how do i send command using infra red in my EFR32FG14 EVM?
Thanks.
Air condioner model.
https://planetaklimata.com.ua/instr..._Electric_PKFY-P_VHM-E_Service_Manual_Eng.pdf
EFR32FG14 manual:
https://www.silabs.com/documents/public/reference-manuals/efr32xg14-rm.pdf
ErnieM
Joined Apr 24, 2011
8,415
I reversed out the IR codes for some devices when I wanted to control them using Alexa. While my Alexa control method is no longer supported the way to reverse the codes is still applicable.
I used an D1 mini board based on the ESP8266. You can get these for a few bucks from many sources. They program over a USB cable, and are very well supported when it comes to libraries. You can tack on an IR receiver such as a TSOP4838 and when you point an IR transmitter at it the transmitted codes will appear in your debug window.
Once you have the codes in your pocket you can reuse whatever micro you used to make a controller.
This kind of thing has been done so many times you can just Google a solution.
yef smith
Joined Aug 2, 2020
1,477
Hello ErnieM,in every I2C component we have command manual so how can i get the command manual to know what kind of commands are there ?
Thanks.
