Hi, quite new to electronics and anything that would help would be very much appreciated.
I am currently designing a circuit for some piezo disc to be able to produce a regulated dc 5v.
as of the moment, all i have is a bunch of piezo disc, connected to a full bridge rectifier each in order for each disc to work individually even if the other do end up being damage, all the rectifiers are then connected parallel to each other, then this goes to a capacitor.
I have thought and tried connecting a voltage regulator to the capacitor in order to produce a regulated 5v voltage and found that this would not work as the voltage regulator component requires certain amount of current to work.
On the other hand, i am currently trying to figure out how a buck converter works and have this component https://shop.pimoroni.com/products/mpm3610-5v-buck-converter-breakout-21v-in-5v-out-at-1-2a at hand to use but cant seem to get any output.
I know the current im producing are quite low therefore the use of the buck converter with low operating current.
anyone have any suggestion as to how i should connect the components and what components i may need to have a regulated 5v? The regulated 5v output would go in a microcontroller where it processed or just read as a signal.
current system at the moment would be like this
any improvement on the system suggested would be much appreciated.
