bountyhunter
- Joined Sep 7, 2009
- 2,512
That's what my guess would have been. Old amplifier designs often used some diode with bizarre characteristics to track the output stage and control idling current. If I recall, some of them were "selected" by the maker. It worked, sort of, but you find so many of these old dogs with blown output stages I wouldn't build one for a new design. Much better options available at lower cost.That old 1S970 again...
If you google for this diode,a big 1000V power diode comes up,so something is obviously wrong.
http://www.vintage-radio.net/forum/showthread.php?t=96571
The diode in module 80 probably(I can't see any other explanation)works as a stabilizing diode since it draws around 12mA of extra current from the midpoint voltage.Now,since the current drawn by the transistor is far lower than that,the voltage across the diode is more or less constant in spite of the transistor's current varying.It stabilizes the amplifier is my theory.
Normally there will be a resistor and a capacitor here.
Try to find a diode that develops a voltage of 0.75V when 12-15mA flows through it.
Have you measured this voltage on your's?
