Creating a AC constant current source for Electrical Impedance Tomography
koolsam
Joined Jan 24, 2017
I need to create an AC current source for my electrical impedance tomography circuit
The output through the load needs to be (1mA rms)
input Voltage source is 1Vp, between 10kHz to 50kHz
Thank you
koolsam
Joined Jan 24, 2017
This is often done with a Howland Current Pump
(From the application note)
Thanks. I have built a circuit similar to this with impedance matching of 1k ohms for all the resistances. Is there a way to measure my rms current across my load? Because when I put a resistance before my load (About 100 ohms) and I take an oscilloscope to measure the Vrms across that resistance, I was not getting a fixed current of 1mA across the load.
Nevertheless I will still try this on a simulation software first. Thank you!
Joined Nov 30, 2010
18,224
Umm...no. You can measure voltage across a load or current through it. If you don't know the difference, that calls into question whether you are measuring correctly.
ps, It puzzles me how to need a constant current from an inherently not constant voltage called, "AC".
You seem to have defined it pretty well when you named, "RMS". I think we can work with that.
You want to start with 1V peak and end up with 1 ma RMS. A current pump can do that but it has limitations caused by the resistance of the load. You inserted 100 ohms. Easy enough. 1 ma RMS is 1.414 ma peak, simple math and a couple of resistor values. 1.414 ma into 100 ohms is 0.1414 volts which the amplifier must be able to supply in both positive and negative voltages. Try doing that to 100,000 oms and it all falls apart because the voltage gets ridiculous (141 volts).
So, watch your load resistance. It's important.;)
koolsam
Joined Jan 24, 2017
Thanks for your answer. I've been wanting to blow my brains out (figuratively speaking), because I was arguing on this point with the PHD student I am working with. He seems to be unable to accept that the voltage will fluctuate when Z(load) changes. He kept insisting that for current to stay the same, voltage must be the same (Which as you have mentioned according to ohms law, that doesn't work). For testing purposes, we are using Z(load) to be a tank of water.
I have tested this circuit across a multisim simulation, and this is the result I got
Increasing the input voltage will give me a higher current at my probe end. So that is not an issue.
I'm using a hypothetical 10k ohms potentialmeter as my water tank here.
I'm guessing I might get a different waveform to this for my actual circuit. I will update again when I have built that circuit and probed it with an oscilloscope.
