Create threshold circuit Challenge
artmaster547
Joined Jan 6, 2016
409
Hi all
I am basically trying to create a circuit, where I can set a reference voltage say 2.8V as one input, then I want another voltage V1 to be compared to this but I only want an output from this circuit of 5V ONLY WHEN V1>2.8V or whatever reference I set. Can anyone please provide any tips of what kind of topology I should use or where I could start.
Art
Reloadron
Joined Jan 15, 2015
7,893
In addition to the link Dogydave was kind enough to provide you may also want to give this link a read, Voltage Comparator Information And Circuits. While operational amplifiers do work in a comparator roll I would try and stay with a chip labeled as a comparator. Also per Dogydave read up on hysteresis in the links as it can be an important feature in comparator circuits.
Ron
artmaster547
Joined Jan 6, 2016
409
Ron
ok great thank you, with comparators is there a setup where the output is either 0 or 5V I know with differential op-amp setups there isn't this almost binary option but rather you get a range of values
artmaster547
Joined Jan 6, 2016
409
Yes the output of the comparator will hit the supply rail, or as near to it as it will go, so if you want only a 5V output, supply the comparator with 5V.
http://www.ti.com/product/LM311
brilliant thank you do you have any suggestions about what I should use to get a consistent voltage reference? Would potential dividing to get a reference voltage of say 2.8V be sufficient or would I need something more substantial?
Dodgydave
Joined Jun 22, 2012
11,395
If you want stability, use a Tl431 zener, better to post the circuit you want to use, then we can assist you further to modify it.
Reloadron
Joined Jan 15, 2015
7,893
If your voltage is greater than 7 volts I would think about using a regulator like an everyday 7805 voltage regulator. I mention 7 volts as regulators like this have a "dropout voltage" exceeding the voltage the regulate at. There are also "low dropout regulators". Either regulator produced by a dozen manufactures so the links are just examples of using a regulator to get your 5 volt reference.
Ron
artmaster547
Joined Jan 6, 2016
409
Hi so the following is a description of the circuit I am after: It's to ensure the "current" of a system I'm designning doesn't go over a treshold. At the moment, I need a comparator that will compare a voltage that will be proportional to the current that has a range of 0 to 3.3V, the reference voltage that I need this input to be compared to is 2.87, or if that isn't possible 2.8 but 2.87 is preferred (if you can provide suggestions that would be really useful). The problem I am having at the moment is choosin components. If you could provide any suggestions that would be extrememly useful.
Kind Regards
Art
Dodgydave
Joined Jun 22, 2012
11,395
Ok so you need the resistors to give a Ratio of 0.148 for a voltage of 2.87V,
So you can use a 1.48K and a 10K, or any combination to give that Ratio.
If you look at any datasheet for the TL431
R1 is 1.48K, R2 is 10K.
The formula is :
V= 2.5 x (1+R1/R2)
artmaster547
Joined Jan 6, 2016
409
The formula is :
V= 2.5 x (1+R1/R2)
ok brilliant thank you so much, do you have any suggestions of what comparator I should use a bit confused with that point I was looking through a lot of datasheets but there are so many to choose from, I need it to give out near 5V or near Vcc when input voltage is greater than 2.87, if you have any suggestions for that would be greatly appreciated.
Art
artmaster547
Joined Jan 6, 2016
409
Ok, search for Rail to Rail Comparator Ic,
EDIT, THE LM311 is an Open Collector, comparator so you can use it, you just put a resistor to pull the out up to 5v.
http://www.learningaboutelectronics.com/Articles/LM311-voltage-comparator-circuit.php
quick question about pull up and pull down, just to confirm with the pull up: unless there is an ouput from the comparator (i.e. comparator gives out 0), there will be 0 totally, but once there is an output it gets pulled up to 5V?
