I have a battery capacity tester (pics below) that draws up to 200W and is dissipated as heat. I can set the amp draw from 0-~30+ but it will drain the battery to zero. I want to create an auto-cutoff that is dependent on the battery type and the voltage of the battery, so it won’t drop below a set point (maybe 60-80% of full charge). I was thinking this might be possible using a switch or relay on the cable connecting the battery being tested (or power supply) and possibly controlled by an Arduino. So if a 12v SLA batt drops below 9.5v it will cut the connection to the battery (while keeping the data on the tester unit. Obviously the cut-off V needs to change for a 3.6/7v Li-Ion vs a 20v Li-Ion.
Since the unit turns the power to heat, I’d like to change that and use the power to charge other batteries (probably the same battery V and maybe Ah as well), maybe this could be done with a buck/boost converter and Arduino?
I have the option of getting 1000’s of battery packs or SLA’s a week that need testing, so being able to do 10-20 tests at a tine would be SUPER helpful!. I’m wondering if multiplexing could be used in this type of setup where the V is measured for the cut-off
I’m also considering looking at some li-ion chargers – 1A TP4056 and 5A XL4015 E1 all because they seem to be well supported and widely used. The li-ion’s I get are 18650’s, 26650’s, 32900’s and 42120’s so some are fairly large Li-ion’s (45-60AH)..
The 12v SLA’s are usually 9, 12, 17, 26, 35, 40, 54, 74 and 95 Ah
The li-ion’s are usually 3.6/7v, 7.2v, 12v, 14.8v, 20v & 60v
I’d also love to be able to output the data test results to some kind of file, CSV, DB, XLS, etc, I don’t think that is possible in the device I have, but maybe if the Arduino were involved it could record this. Recording to microSD is OK, though network connection is better IMHO.
