No audio out with signal at Line In, nothing from the speaker out or Line out. When I inject audio into the Instrument input I get audio to the Line In jack so its after thatCan you inject a signal to the Line In and check if there is audio out from the speakers?
Line out and line in are about the halfway points in audio systems.
Make sure all controls are about mid position.
I think the Line In makes more sense, I'll start going through the voltages my biggest issue is figuring out which component is which, I'll pull the board and map it as best I can, I do have an O'Scope so I can see those P-P voltages now. I really appreciate the help.On your schematic, you have voltage levels listed. Can you compile a list of locations you tested and the voltage you observed there? In case you haven't realized it yet ... I like copious notes.
Since you injected a line level signal at the Line In Jack and you had NO audio at the speaker, we can work on that problem first. Or if you prefer, you can inject a signal at the instrument in ... which is probably around 10 mV rms ... and repair it till you get the LINE Out.
Which one do you want to start the effort ... Line IN to speaker or Instrument IN to Line Out?
