I was just curious what the CPM reading would be (approx) if you took a geiger counter and placed it at/around/near the strongest point on an xray machine or tube. Do X ray machines emit extreme CPMs ? What would the strongest reading look like?
Yes, I get that they do not radiate them outside the machine. My question is if a geiger counter was placed at, in, near the most point of collision. What would be the CPM range one could expect to see on a geiger counter.? I probably didn't word the question properly, I'm sorry.Hello,
A good x-ray machine does not radiate x-rays outside.
The x-rays should be shielded for safety reasons.
Most times there are safety switches that cut the power to the x-ray source when the machine is opened.
Bertus
X-Ray particles?A medical X-Ray machine makes enough particles to make a high resolution moving image on the monitor. That takes a lot of particles per second.
Actual count? A LOT!
That is a really bad example because you forgot to say you were doing the experiment in a vacuum. X-rays are strongly absorbed by air. Your 2meter example is way, way, way overestimated if you are in air.If you had a 1CPM at 1 meter, at 2 meters you'd have 1/4CPM.
Learn something every day. Thanks.That is a really bad example because you forgot to say you were doing the experiment in a vacuum.
As an X-ray service engineer we always use the inverse square law to determine the dose regarding distance. Works fine in air! Most X-ray examinations are taken with a 115cm distance between tube and film( or digital plates). Sometimes a source image distance of 180cm is used, this is done to reduce the magnification on the film.That is a really bad example because you forgot to say you were doing the experiment in a vacuum. X-rays are strongly absorbed by air. Your 2meter example is way, way, way overestimated if you are in air.
What energy are the x-rays?As an X-ray service engineer we always use the inverse square law to determine the dose regarding distance. Works fine in air! Most X-ray examinations are taken with a 115cm distance between tube and film( or digital plates). Sometimes a source image distance of 180cm is used, this is done to reduce the magnification on the film.
The particles are quanta, and are exactly as you describe on a fluoroscopy procedure. Fluoroscopy is when the image is 'live' and displayed on a monitor screen. The X-ray tube will be operating between 40 to 110kv depending on patient object thickness, at tube currents upto 5mA.Like the photon wave/pariticle duality. Under a low dosage rate you can see the "twinkling" and "crawling" on a fluoroscope screen.
| Thread starter | Similar threads | Forum | Replies | Date |
The World's Most Important Machine | Off-Topic | 0 | |
Logic D | Homework Help | 53 | |
Line-Trace plasma cutting Machine | Sensor Design & Implementation | 5 | |
Powering DD motor from washing machine ..#2 | Power Electronics | 10 | |
| G | NordicTrack running machine MC2100ELS-18W speed issue | Technical Repair | 1 |
