Count Up To 2 Counter With Automatic Reset Needed
russwr
Joined Aug 29, 2017
129
Circuit IC part number and / or circuit sketch needed so as can count to 2 , up counter with automatic reset with input initiated by Hall Magnetic sensor. 12121212. The 2nd pulse will initiate NE555 monostable timer with an output pulse to turn on transistor that connects a different terminal to ground for milliseconds of time.
28,181
How long will that pulse need to be?? A CD4017 can count up and the higher outputs can easily frrd an OR gate for up to 7 or 8 count intervals until the reset arrives.
AND, for once the TS has stated the requirement at the very start of the thread, without asking how to make something work. I applaud that correct process!!
