Count down/up timers
jey11
Joined Jun 7, 2010
25
16 bit, 5 time and want to count for a Mhz count up for a 3 ms interval. What value should I put in data register. How to calculate this.
Thanks for the help
Jey
jey11
Joined Jun 7, 2010
25
16 bit 10 Mhz count down timer. If the timer data was previously set to 0x7A2B . What is the count down timer interval? How to find this.
Steps might help.
Jey
35,023
Thanks for the help
Jey
There are two many unknowns.
What do you mean by 5 time?
What MCU?
What is the system clock frequency?
LesJones
Joined Jan 8, 2017
4,522
If you mean that you increment the counter every 200 nS (5 Mhz) then you need to count to 15000 (Decimal) Normally counters set their interrupt flag when they overflow so you need to pre load the counter with 15000 less than the overflow value. A 16 bit counter will overflow at a count of 65536 so you need to pre load it with a value of 65536 -15000 = 50526 which is 0xC568 Hex. In practice you have to make a correction for the time it takes to load the counter. You write the code required to load the counter then work our how long those instructions take to execute. You then add the number of cycles of 5Mhz that represent that amount of time to the value you load into the counter.
Les.
jey11
Joined Jun 7, 2010
25
Steps might help.
Thanks for the help
Jey
jey11
Joined Jun 7, 2010
25
Les.
Thanks for the help and explanation.
Can you assist on this too please.
Steps might help.
Thanks for the help
Jey
LesJones
Joined Jan 8, 2017
4,522
0x7A2B = 31275 decimal. As you are now talking about a count down timer (Rather than a count up timer.) the situation is different. (I have not seen a countdown timer on any of the microcontrollers that I have used.) I ASSUME that in this case the interrupt would occur when the counter decremented to zero. (You would have to read the datasheet on the microcontroller that you are using.) If my assumption is correct then the actual counting part would last 31275 x 100 nS = 3127.5 uS
Les.
35,023
The computer does not care whether the number is in decimal or hexadecimal. The computer works in binary alone.
Hence make your life easier and enter these numbers in decimal because that is what humans recognize easily.
jey11
Joined Jun 7, 2010
25
Les.
Thanks for you support.
