We won't work your problem, or parts of it, for you. We will try to guide you along a path where YOU can solve YOUR homework, so that YOU learn from it.It's to find norton equivalent circuit but if someone can help me with finding Vo, it's enough i will do the rest. No need to do the norton eq. circuit.
Don't be sorry, clean it up!I know it's really comlicated and written badly,sorry about that.
I ask about it because the circuit will be much simpler if you want to find Isc (Norton Current) directly.It's to find norton equivalent circuit but if someone can help me with finding Vo, it's enough i will do the rest.
I thought you were supposed to find a Norton equivalent? Do you know how to perform a mesh analysis? A quick and easy method can give the Norton parameters in a very straightforward manner.Thank you for your help guys. I was in a little bit hurry because i had to deliver the homework. I solved the question like this:
