Hi, i put together my first ic based circuit, a 555 strobe. If i could i would like to have more experienced eyes look over it to make sure it is not on some kind of slow buildup to destruction or some other horror scenario i can imagine.
Glad i bought 555 timers in bulk. I burned out three trying to figure out how to do my first 555 circuit. XD
Linked below is the circuit simulation.
http://www.falstad.com/circuit/#$+1....0+0.0+0.0 o+5+32+0+35+10.0+9.765625E-5+0+-1
I built the circuit as shown and it works exactly as simulated, is flashing away beside me. Aside from general worries about it catching fire or exploding, i read at one point that you need to have a diode going in parallel with r2. I have it in the simulation and the actual circuit, but when i remove it from simulation it makes 0 apparent difference.
Was i misinformed/ read it wrong and don't need that diode?
Also, all my resistors are 1/4 w. I know that's fine for the current going through the led, but is there a way to calculate the correct wattage for R1 and R2 on the timing circuit?
